I've fubared my alternator after drowning it in sludge a few weeks back so I'm trying to get it off and see if it cleans up.
I'm following this article on the aus forum and got to stage 2 before I got stuck
This is my pic
First off I tried undoing B and it undid till I had a good 6mm of thread out but the belts are solid.
Then I tried bolt C at the end of the bracket, but it was still solid so did it back up again.
I've tried to undo A but its stuck solid. Sprayed penetrating fluid on it and I'm just rounding the head off.
I'd try harder but I don't really know what I should be undoing to release the slack on the ac compressor belt drive, the aus article just says 'release the tension'
Advice please.
This is my pic
Advice please.
