I have a 97 ssrx 3L td auto which I purchased a few weeks ago.
When I press the 4wd button I can hear the relays working but get the flashing centre diff light. Pipework/wiring looks ok. This is me moving slowly 20-30 mph. However when I go round a corner (either left or right) I get the click from the gearbox and it engages 4wd. Does anyone else have this issue? I assume it is not normal. Any ideas what the cause is?
Thanks
Thanks
Don’t drive for more than few hundred yards with the lights flashing or you will wind up the transmission, this is because of the slight differences between front and rear wheel transmission ratios. This is particularly true if a sharp turn is taken, as the front wheels will now be drawing a different arc to the rear wheels and therefore will rotate at a different ratio/speed i.e. the inside front wheel will turn slower than the outside front whilst the transmission is trying to make all four wheel turn at the same rate, until the centre diff is engaged (Four Greens not flashing) then you can turn the wheel to your hearts content as the front and rear wheels are effectively being driven independently of each other through the centre diff.
