I seem to have a problem with the brakes on the surf. The brake warning light on the dash has lit up, the brake pedal is rock hard to press whether the engine is running or not and it basically doesn't brake very hard when you do manage to press the pedal slightly.
I have checked the obvious like fluid, haven't checked the calipers as its dark and late, but was wondering if anybody had anything like this happen before or if you had any ideas what to check.
