u-joint replacement
  • u-joint replacement
    hey guys ive a weird noise when im driving its builds up and is louldest around 80klms. the noise stays when i knock it into netrual while driving and also when slowing down.
    its a knida howling whining sound.
    ive done a good few searches and i think its the u-joints.
    how many u-joints do i need and the best place to buy them. i will have to get them shipped as im in Ireland.
    its a
    97 4speed auto 2wd with selectable 4wd diesel.
    cheers
    Toyota, Milners or Roughtrax. How many you need depends on how many are shagged. If you haven't greased them up previously, that would be your best starting point. One or more may just be running dry, so to speak.
      If your local motor factors can get blueprint parts you need part number ADT33905.
      Trev
        how many is there?
        i checked out roughtrax and found these
        http://www.roughtrax4x4.com/?doc=16&cid=178&vid=192
        but whats this
        wide angle joint at the Transfer box end on the front prop.
          The Surf has 5 Uni Joints. One each end of the tailshafts which are all the same. There is another on the front of Transfer Case which is called a Double Cardan Joint. This is a different and more expensive joint.
          Nev
            thank you ^^
