Noticed yesterday. Feels slighly like the 'buzzy' feel through the steering with mud tyres (but I'm running BFG ATs) and happens (only on acceleration) round about 30-40mph.
I replaced a wheel bearing last weekend and thought it might be that bedding in. It was slightly slack so I tightened it up a bit, and did the other one as I was at it. It seemed OK afterwards, but this morning its still there though only slight.
I've had a look down at the belts to see if there's any undue movement in the pullys but all looks well. Is movement easy to see, or is it not that simple? One thing that makes me think 'pulleys' is I removed the aircon belt last weekend as it looked ropey. I have another to put on, but haven't done it yet.
One last question. The 'harmonic balancer'? Is it just the two bonded pulleys?
<edit>
Just been for another drive. I dont think its anything sinister otherwise I'd feel the vibration through the gearshift and low ratio selector.
However, what I have done this week is re-bushed (with Milner polybushes)/ re-fitted the front ARB for road use, so maybe I'm feeling the tyre tread / road surface through the steering now the front suspension is stiffer again.
<edit>
