Hi All,
Looking for a bit of advise, as the surf is refusing to start up on turn over.
I had the RAC out and they advised the problem is probably the Solenoid or the fuel pump, as no fuel is getting to the injectors. He also advised that the glow plugs are also not getting any voltage.
Would the Solenoid cause this issue in the pump and can anybody suggest any tests that I can carry out to prove where the problem lies before I start swapping out various bits.
I have also noticed that the glow plug light on the dash doesn't come on when tuning the ignition on. I have also been running on 50/50 veg oil from Tescos for the past 6 months without problem and was planning on changing the fuel filter first.
I have seen a previous thread where they mentioned it was the ECU, Is there anyway I can test it.
Thanks in advance for any advise, missing her whilst driving wifes car.
