Evening All,
Before I start buying replacement air con unit, is there any servicing I can do to the present pump set up?.
There is a high pitched squeal when ever I switch on the air conditioning system, from the centre of the wheel and it looks to keep sticking. The belts seems to be tight enough, so can only assume that there is a bearing in the middle that has seized up or issticking.
Has anybody offer any advice on serving it and help advise what I need to do.
Thanks in advance.
Also, Can I take the unit off, whilst servicing it and keep driving the car?
Thanks in advance.
