Guys,
The few Surf 3.0l manual sellers I have contacted, have decided not to respond, so I figure that I might as well look for a UK model and then add Surfy bits to it (Intercooller bonnet, wraparound bars). I have had JDMs for a while and have used the air-con in anger, only once or twice, apart from the maininance 15 min runs that they need - so I wont miss nowt there. The Chromy bits can be attained by some detailing and more transplants from the JDMs.
How well do the Surf/ 4-Runner 3.0 TD engines take to high mileages? I found one today thats done 110,000 miles and it is a 1996/97. Its a UK 4-runner that has towed a caravan about "3 or 4 times last year". Apparently the belts have not been changed on it "because the change light never came on...." and the owner believes that it has a timing chain unlike the Surfs.... uh...
She does have a Full non-dealer Service History, with no indication of belt changes etc.
At the mileages spoken about, I guess we are looking at worn rear springs etc that you guys speak of on surfs, a set of E9000S + 2" springs might sort these out? Ditto steering idlers? Anything else I need to look at?
Basic worry is are these engines going to be bullet proof if they were serviced regularly? How would I check up on these diesel thingies; When do Turbos need overhauls on these? How do I check for doofy'd turbos?. I have run a Petrol Land Rover for ages - rule of thumb in its maintenance is "if doesnt leak its out of oil, if it doesnt sqeak then the squeaky thing has fallen off, PULL OVER NOW!", but I guess these Surf/4-Runners are a different kettle of Sushi?
TIA as usual.
Regards
Udhi
She does have a Full non-dealer Service History, with no indication of belt changes etc.At the mileages spoken about, I guess we are looking at worn rear springs etc that you guys speak of on surfs, a set of E9000S + 2" springs might sort these out? Ditto steering idlers? Anything else I need to look at?
TIA as usual.
Regards
Udhi
I havent had a snoop at one so I wouldnt know off first hand experience.
