Well what a month I've had.
Started, white smoke = cracked head,
so brand new head, bubbles in cooling water, pushing water out of the expansion tank.
New head removed found blown head gasket, head gasket changed.
Still same problem, garage trys to clear any air from system, still no good.
Head off again and replaced with another new one, block also checked, still the same problem, has new thermostat rad cap and water pump.
Then to top it all off developes a terminal rattle in the lower nearside of the engine!!!!
So back to the garage who say they can not confidently diagnose the fault and recommend I take it to the main Toyota dealer.
So I tow it to the dealer who after stripping tell me that the balance shaft is broken and I would need a short engine £4650.00 fitted.
Of course I will not be spending over 4K on a new engine, but what do you think I should do now?
Sell it as is, 1996 KZN185 SSR G in otherwise very good condition, how much do you think it's worth?
Try to find a second hand engine pay for the change and hope it is ok?
There is a company on ebay selling imported engines with 6mths warranty for £950.00, anybody ever used them? Iezura?
Many thanks,
Mark.
Many thanks,
Mark.
