would low oil preasure cause overheating? coming back from cornwall yesterday i noticed the temp gauge going up on all the hills under acceleration. the oil preasure gauge is just below the line and when accelerating it moves to just above the line, but the temp gauge carrys on creeping up. once you ease off the gas it goes down and sits below the line again. when i got a chance i pull over and checked for water. the exspansion bottle was full and bubbling like mad, took the rad cap off and had to fill with 2 litres of water. it's had fresh oil and a new filter put in it, 2 days ago. i'm guessing it's not the cooling system, but the oil system that is causing the heating problem. is the oil pump is on it's way out? or what else could it be?
suggestion welcome
suggestion welcome
