G'day,
Do any of you guys have any experience in ripping off a fuel injector pump on a Hilux Surf 3.0L 1KZ-T engine? Mine is pouring fuel out from the underside and a rapid rate of knots. I can't quite locate where it is coming from. It is not from any of the pipes, they are all tight and dry. It appears to be right underneath in a very hard to view spot, even with a proper mechanic mirror.
I assume it's going to be a nightmare getting it out but if any of you guys or gals have done this, I would love to know if you had an easy time or hard time with the job?
Chris
Chris
