I have a 1kz-te 95model. The symptoms I am having are as follows. The engine runs perfectly otherwise no noises from the engine, turbo kicks in smoothly when needed. However there are times when on startup the engine shudders like its not getting any fuel when left in idle and if I drive it the engine will cut off when I am on the road and since its an automatic, i have to put it in park and turn the ignition off and then turn it on and it will work like a charm after that. Also if I wait for about 2 to 4 mins in idle after i startup and notice the shudders starting after waiting for this time when i drive it, it works fine after that. Any ideas on what could be causing this?? As I mentioned this is very intermittent including the shutdown otherwise the engine runs very smoothly. HELP!!!! The engine cutting off when I am on the road is too risky!!!
Intermittent Engine Shudder and Shutdown
Hello and welcome
I'd check a few things....
Fuel pump
Injectors
ECU - try resetting this by disconnecting the batteries and keeping the terminals together for 5 mins (I've used cable ties)
If it doesn't do it hot, it may be gunge in the fuel filter too - once the engine is working and pumping more fuel through the system, it keeps going - but when cold it may be fighting through sludge to start with...
Just a though - wait here for the experts....
ECU codes read normall... continuos on/off flashing. Also the surprising thing was that when I replaced the diesel fuel filter it had stopped doing this for two days and gradually came back after the third day.....so far it hasnt cut off the engine when driving, but at times in the morning the engine sort of revs on its own - I even popped open the bonnet to see if the accelerator cable moves on its own
 "gremlins" but nothing, all you see is the engine turn like when you increase the throttle. any assistance advise would really help ease the pain!!!
What I have done so far,
A. I replaced the fuel pipe intake which was very loose going into the fuel filter pump section but that didnt help.
B. I replaced the fuel filter pump itself since it might have been letting fuel drop back into the tank but that still didnt fix the problem
The symptoms have been getting worse so far and now when the car is parked for 9 hours it will start with no problems but will then increase the revs and the engine shutsdown. If you look at back from the exhaust it takes out a cloud of black smoke. Then when you attempt to restart it, it restarts with no problems and then again the revs increase on its own and again black smoke out the back and the engine shutsdown. After the second time when you restart it, it cranks straight away and stays on this time and will not idle smoothly for around 2mins or so and then its fine. When driving it after this there are no shutdowns or rough idling or anything else and works 100% no issues....If someone can guide me as to what it is that exactly could be causing this it would be great help....the engineers in my area dont know much about diesel engines and will muck up the entire system.......Any more advise would be appreciated.
not being over familiar with the surf diesel engine, but am familiar with toyota petrol engines i was wondering whether the fuel pump has its own ecu which controls it, these eventually fail in normal running and are still ok in cold running but as soon as the ecu changes over the fuel is virtually cut off consiquently the vehicle either loses power or cuts out.
What I have noticed is I have to wait a bit around a minute when I start it and it works fine without these issues.......before i never had to wait this long to crank it. Normally around 20seconds before cranking and it was fine now i wait and then everthing is dandy...does this put light on what is the problem???
Could you explain this please?Originally posted by MudSurfer View PostHello and welcome
Fuel pump
Injectors
This problem got worse and started shutting down the engine while I was on the road. I decided to open out the ECU and check if there was anything wrong with it. On closer inspection I found out that a few of the capacitors inside had leaked the liquid and caused a corrosion on the board. Hence the issue of it shuutting down and causing all these problems. I got the capacitors replaced by an electronic expert and so far even with the weather raining and it getting cold in the morning she starts back up like she used to.....hopefully this problem is fixed for now. Am on day 4 now with no worries....lets hope it stays that way!! Hopefully this will help somebody with a similar issue like what I was having.
Thanks for all the advice I got......
