Hi, my name is Tiff and I have a problem with my 1993 4Runner 3ltr TD ( KZN 130 engine ).
Even from cold, the coolant is being blown out at higher revs. The coolant tested positive for exaust gasses.
Prior to having this problem, a new radiator had been fitted. I have now fitted a new cylinder head ( old one cracked ), new thermostat and checked the water pump for wear and hoses for obstructions (all ok).
On the first test run, going up a steep hill at highish revs, the water suddenly blew out and I ended up with the new head warping.This was then refaced. On re assembly with more new gaskets, I still have the same problem. The head was again removed and crack tested, proved ok. As far as I can tell at the moment, the bores do not appear to have cracked and the top of the block is not warped or cracked.
As the turbo has a water cooled bearing, is it possible for the exaust gasses to get into the cooling system via this?
Any ideas will be appreciated, Tiff Amsdon
