Morning peeps its been a while been a busy bee with my gaming website (http://www.pimpmywii.co.uk) and the dreaded work aswell,
Had a shock of my life this morning when heard a metallic grinding noise coming from the engine bay while on the M18, turns out one of the 2 belts has shredded from the alternator doo dahh... luckily still got one left on but got RAC out anyways who were very helpful, I have ordered a drvebelt set from roughtrax and also a timing belt as the lights on and its been a couple of years since that was changed.
What i'm after is some instructions for changing the main belts, i have found one for the timing belt but cant find any for the drive belts.
I have searched the forum, and the links within them ie to the normal places dont seem to have the instructions for the 3.0 version.
http://toyotasurf.asn.au/techsite/3lt/drivebelts.htm
as you will see from the above link that it seems to be under construction (booooo) and being a noob could do with some guidance..
Any help would be appreciated as need to get this done tomorrow when the belts arrive so can get to work sadly...
Ta in advance
Stu
Ta in advance
Stu
