Hello,
I wanted to show how we did the intercooler install on my 3.0TD 4Runner.
This is the intercooler used, from a Mitsubishi Pajero 2.8:
Also bought some constant radius SS bents:
As I don't have a body lift, we chopped the top of the valve cover and used some aluminium sheet to cover the hole.
Also we fabbed some beefy brackets for the intercooler:
Tacking the piping. Notice the radius of the pipes is constant:
Turbo exit piping
Intake entrance / Intercooler exit piping
Tacking the intake flange
Fabbing the intake flange
We changed the intake rubber hose for a different one. It has steel wire to prevent squeezing
Finished intake flange
This metal tube addon is temporal
This week we'll be installing the hood scoop and padding around the intercooler.
All of this was complemented with a 70mm SS exhaust with constant radius bents and an injector and pump rebuild.
Hope you like it.
David
Turbo exit piping
Hope you like it.
David
) i wish!!!! i certainly could do with you here regarding the exhaust, i'm going to try sticking together a 3" s/s one soon, i was reading your post on Yotatec a while back, top work mate, keep it comeing,
, I believe the odd v6 auto found It's way into the Uk in the early to mid 90's.
