How easy...or how hard is it to take off the cylinder head on a 1kzte?
Iv'e got the rad out at the mo and viscous fan off, also the ali crossover pipe
as I was in the process of making up a top mount intercooler. The rad was having a leak from the filler neck soldered up by my local rad shop when we found the 2 year old 4 row core has expanded!!
Iv'e owned the surf for 5 years and It's never gone in the red, got a tad warm when towing up long hills, the electric water temp gauge hit 110 degrees once(sensor in top hose) but soon cooled down.
Has had new thermostat, rad cap, flushed, viscous reoiled , toyota red coolant since I owned It etc etc.
been pressure tested,
been combustion gas tested,
been compression tested,
All by ex Toyota mechanic who I trust and all is good!
It doesn't appear to lose water(apart from the leak by the filler neck which was marginal)
So It's all ok then!!
So why has the feckin rad blown?
Do I take off the head at this stage or do I chuck more money at it (intercooler etc) and just not be bl**dy paranoid!
Taking the family on holiday to north wales in the caravan in August, It's booked!
Talk about concentrating your mind!
![Wideeyed](https://hiluxsurf.co.uk/core/images/smilies/wideeyed.gif)
