Hi
Got a possible oil leak on what i think is crankseal?! on a 3.0TD 4runner,
this follows an oil change, slight overfilled it by 4mm, but drained off excess after 50miles of driving (by unscrewing oil filter a couple times).
i did spill some oil when filling, but there still seems to be a slow leak when driving.
it is from around the two pulleys that the fan belts go on, right at bottom of engine, and not the timing belt cover region,
i think the crank seal on a 2.4TD is on the timing belt? seems to be different on a 3litre,
has anyone changed this seal? is it easy? any helpfull tips?
cheers
cheers
