OK guys, following my weekend exploits I need to remove my radiator, clean it out, and refit it. I've searched the forum and found tips for a 2.4, but just thought I double check for a 3.0.
Do I simply undo the lower fan shroud. Undo the pipes (blocking the smaller ATF ones, and try to catch the ATF fluid that will drip out the radiator). Undo the 4 or so bolts, and lift?
Any tips on cleaning the fins out? Bearing in mind that the mud it's clogged up with has a tendancy to set like concrete.
I'm guessing that a jet-wash on full blast isn't a good idea.
