Turbo Oil Drain Pipe
Ok I have read all the posts on this one but just like to confirm......
Can you replace this pipe with everything in place? Some suggest it's just possible. Others mention micro hands may help!
The two bolts to the block I can reach. The other with the banjo fitting is the unknown.
Also I don't want to lose a drop of oil and have clean faces
when I reassemble.
when I reassemble.
Appears mine was just the lower gasket on the main pipe!
