Good Evening, I'm having some issues with with my Gen 3 3.0 , I've owned it for almost 6 years now and this is the first problem I have had, so I guess I can't complain
My Missus drives it mainly and she says at tick over it randomly sounds like it it's going to cut out, when pulling up to a junction etc, the revs will suddenly drop for a while then recover (she says that it appears to be worse when cold), also (this is the scary part) occasionally it will hunt forward, so for example as you are slowing to halt it will it suddenly increase speed slightly, lastly when running on a clear main road it will very occasionally lose power just for a couple of seconds (I've experienced this myself). Sorry for not being able to explain it better.
I'm not sure if this engine related or gearbox, I don't really want to take it to a garage without being for-armed with some knowledge of what the issue might be or from past experience I can just see myself just being ripped off.
Any advice, ideas would be appreciated, thank you.
, I did search but it did not turn up anything relevant.
