Hi all
After 2 years of surf ownership it would seem I have my first problem.
It comes in that the AC doesn’t anymore. After being out in the rain on sat, me and a very soggy dog jumped into the truck, before I get the engine started the windows steam up straight away - as they do. Putting the ac on usually sorts this is seconds. However not this time, didn’t shift the misty windows at all.
After a brief inspection the clutch on what I presume is the pump does engage but only momentarily before disengaging again (1-2 secs). The fan on the ac rad also activates simultaneously with the clutch on the pump. Also, the engine revs used to increase to about 750 (idle) with the ac on, now there is no change idle is about 500 (manual trans).
Thanks in anticipation
Chris
Chris
