i have a few questions re my surf, my rear window washer does not work ,is it on a seperate water bottle/pump to the front if so where is it situated?
what is the correct tyre pressure 165 x 16 tyres i am currently running at 30psi all round ?
also i have read in the hand book that it is more economical to run with the overdrive off than on , my soarer apears to be the opposite, have you any comments on this?
are the headlamp side lights 5w capless (push in folded wire type) as i have 1out?
disco now gone aswell
put it down to age
