I'm currently considering a two tank conversion for SVO but have recieved conflicting information regarding the type of injector pump fitted to my 1995 3lt 1kzte Surf. Can anyone definately confirm whether it is a 'Rotary' or 'In-Line' type pump. It is important to get it right as the wiring/installation set up for the conversion depends on which type of injector pump is fitted. Has anyone done this conversion using an ATG Twin Tank conversion?
1KZ-TE Injector Pump Type
Pump Query
As far as I can tell, if the injector pipes come out of the end , rear, of the pump you have a "rotary", or DPA type, and if the pipes come out of the top of the injector pump in a straight line then you have an "in line" pump.
As far as I know Toyota stopped using inline pumps due to the higher cost and this was possibly more than 15 years ago.
My last Landcruiser "H" reg was a rotary, and the one before that had an inline.
The inline pump is 100 times better than the newer cheapo rotary and can pump almost anything you could pour into it.
Hope this helps
Yeah, this is how all the Surf pumps are.Originally posted by muller1As far as I can tell, if the injector pipes come out of the end , rear, of the pump you have a "rotary", or DPA type...4x4toys.co.uk - Keeping you on and off the road...
Dont need to get a fantastic, all bells and whistles system for these trucks, just the basic set-up works a treat.Originally posted by SilversurferI'm currently considering a two tank conversion for SVO but have recieved conflicting information regarding the type of injector pump fitted to my 1995 3lt 1kzte Surf. Can anyone definately confirm whether it is a 'Rotary' or 'In-Line' type pump. It is important to get it right as the wiring/installation set up for the conversion depends on which type of injector pump is fitted. Has anyone done this conversion using an ATG Twin Tank conversion?
£475 gets you a really good quality set up from dieselveg.com it includes everything, ive had mine on for 6 months now.Without Surf And Unhappy
Nil Illigitimi Carborundum
