Hey fella's,
Couple weeks back I did a straight g/box swap on my Surf due to a crook first gear. Had spent about 6 months on 2nd gear starts, and while I was aware of how excellent that was going to be for my clutch, I was a student etc and couldnt afford the repairs.
Anyway, finally made the swap to a 2nd hand box which has been awesome thus far. But today, after a few skips and some funny rattly noises the clutch totalyl shi*ts itself, I'm getting traction only in first gear and only at about 20Kph. Any higher, and any kind of incline and it starts crunching away and doesn't go anywhere. Revs do tho.
So, I'm guessing [from conversations with mechanics and research on the net] that it's the pressure plate...I'm not entirely sure, but I've got a price on whats being called a one-piece clutch kit which includes a flywheel [not sure of mass] from a previsouly working model. [flywheel / thrust bearing / pressure & clutch plate ] which is at a great price [400 compared to close to a grand for new]
So couple things I need to know before I tear it all apart again:
- What's the diference between a one and a two piece clutch kit? Are they interchangeable?
- Is there any special tool[s] required to re-fit a clutch?
- Is there any special distances or hi-precision placements I need to know about between plates etc?
- Any torque settings anywhere? Technique to doing bolts up?
- Any balancing required?
- Crazy to use 2nd hand parts? If so, can I get away with a quick machine of the flywheel and only replace what's $$$$ped out? I.e pressure plate etc?
- Any bearings / seals I should do while Im in there?
Any help or advice at all would be wikkid, I am hoping to document and photograph the ordeal so as to share my findings and experiences with those sharing my predicament so will try to give something back to the forum once this is all over...
Cheers,
G
Cheers,
G
) I'd avoid fitting a used one if at all poss and fit a conventional style clutch and flywheel.
