not that it bothers me unduely, i would'nt have bought the machine if it did, but i did a mpg check on a tank full of fuel and over 3/4 tank which appeared to equate to 47.61 ltrs(thats what i put back in to top it up) i had travelled 400 miles ,which if i have worked it out right is 8.4 miles to 1 litre of diesel (10 gallons) which means i'm getting 40 mpg, am well pleased with that on a 3ltr turbo intercooled engine .probably do better if i did'nt have such a heavy right foot i wonder if the injecter cleaner i put in helped?
mpg
ah never thought of that . good point 400 km's = 248.55 miles which now equates to 24.85 miles per gallon which is about the average that my 4 ltr soarer gives .but then again the surf is lugging a lot of kit about.
i suppose i can prove it one way or the other by travelling a known distance route.Last edited by soramad; 10 November 2007, 23:08.
Originally posted by soramadah never thought of that . good point 400 km's = 248.55 miles which now equates to 24.85 miles per gallon which is about the average that my 4 ltr soarer gives .but then again the surf is lugging a lot of kit about.
i suppose i can prove it one way or the other by travelling a known distance route.Without Surf And Unhappy
Originally posted by soramadnot that it bothers me unduely, i would'nt have bought the machine if it did, but i did a mpg check on a tank full of fuel and over 3/4 tank which appeared to equate to 47.61 ltrs(thats what i put back in to top it up) i had travelled 400 miles ,which if i have worked it out right is 8.4 miles to 1 litre of diesel (10 gallons) which means i'm getting 40 mpg, am well pleased with that on a 3ltr turbo intercooled engine .probably do better if i did'nt have such a heavy right foot i wonder if the injecter cleaner i put in helped?
chuck some veg oil in mate , it eases the pain at the pumps.
god may forgive me for keeping this thread going........girls may not.
18mpg 19mpg 20mpg depending on mood. Drive like a girl and you don't even need disc brakes.
22mpg has been best. 16mpg is 3.0 fun time. Better than the V8 in any mood.
Have a leaky turbo to exhaust manifold? may make a difference.........in my dreams.
Main issue at the minute is how to keep the exahust fumes from being sucked in through the rear window I will search a remedySmack it with a 16lb Hammer and it will come off!
Main issue at the minute is how to keep the exahust fumes from being sucked in through the rear window I will search a remedy[/QUOTE]
have the end of your exhaust turned at a right angle to come out behind the rear wheel that will probably help.
Originally posted by soramadMain issue at the minute is how to keep the exahust fumes from being sucked in through the rear window I will search a remedy
It's SO tempting to mention the blindingly obvious - close the windowLook out Eastbourne, the Pandas are coming !
Originally posted by internetsurferchuck some veg oil in mate , it eases the pain at the pumps.
It's SO tempting to mention the blindingly obvious - close the window .Smack it with a 16lb Hammer and it will come off!
