Hi
Just fitted a new exhaust system on my Prado 3.0 ltr turbo diesel ,system was middle and back muffler from Milners .
When i start it up first time in a morning it seams to blow some black smoke out which is slightly damp leaving speckles on my garage doors.
The smoke only appears on start up and if you reved throttle excessively,ok when running normally
Checked water levels all ok
Checked oil levels all ok
There does not appear to be any problem with performance etc and fuel usage is abouit the same.
I was wandering if i was getting any moisture in the diesel but would that not effect the performance ?
It has only done 76000 miles
