Timing Belt Change
    Originally posted by Vagrant No2 View Post
    Not on the luxury 3rd gen . 5 or 6 screws and dash is out and little screw moved into other hole and reassembeled 10 mins tops.
    All we need now is a 'How To'? on the t-belt light procedure!
    on the 3rd gen preferably for me..
    Great right up by the way!
    CURLY
      I know it's an old thread but I thought I'd say thanks anyway - I saved a bomb using this advice and changed the belt and bits yesterday whilst I was changing the radiator.
        Is it the same on a 3.0ltr KZN130?
        ta
          ta
          Harder on a kzn 130, more bits to take off.
          1 hour on a kzn 185.
          Half a day on a kzn 130.
            Tut tut Si, it's the LN130 (2.4) that takes a few hours not the KZN130 (3.0).
            The KZN130 and KZN185 share the same engine, just different bodyshells.
              My bad.
              It's been a while mate sorry.
                So is it as easy?
                Do I have to do anything different?
                It's about time I lavished a bit of love on my old girl.
                Steve
                  So is it as easy?
                  Steve
                  I did mine on my kzn 185 & I'm no spanner monkey, I even did a write up on it.
                  http://www.hiluxsurf.co.uk/showthrea...hlight=Cambelt
                  • #24
                    Nice
                    Thank you
                    Steve
                    • #25
                      would you recommend a genuine belt or is the dayco belt just as good?
                      www.floatingpontoonsolutions.co.uk
                      • #26
                        With things like cam belts I always go for genuine just to be extra safe but it depends on your budget. The non genuine will be fine, I'm just a fussy git.
                        • #27
                          Yes you have just confirmed what i was thinking, for a few extra pounds its not worth the risk. my surf is used daily to deliver pontoons all over the UK it has to be 100% reliable which up to now she has never let me down.
                          • #28
                            Hi Guys,
                            I don't think you can go far wrong following this video.
                            Doing mine this afternoon....
                            http://youtu.be/qNTgWjRY_dc
                            Andy
                            • #29
                              All went well, took about 1.5 hours and about 15 minutes to reset the warning light by removing the clocks.
                              Andy
                              • #30
                                Excellent again just taken over hslf an hour to do
