story so far.......last sunday car overheated off the thermometer scale...came off the m,way allowed to cool down filled up with water and limped home but noticed a slight rattling sound that sped up with revs....monday did engine flush oil and filter change.....started up rattling a little louder....tuesday went to work 12 miles away rattling got louder and louder...limped home again turning heads all the way...oil colour is normal and general running of engine feels smooth apart from the regular rattling/knocking sound u guys any ideas what the problem is??
knocking part 2
i might be wrong but from what you are saying i reacon your turbo is gone.You have the same symptoms as i had back in December as i said in your other thread.You can get a 2nd hand turbo for the 2.4's easy enough and that is a CT20 turboOriginally posted by hallystory so far.......last sunday car overheated off the thermometer scale...came off the m,way allowed to cool down filled up with water and limped home but noticed a slight rattling sound that sped up with revs....monday did engine flush oil and filter change.....started up rattling a little louder....tuesday went to work 12 miles away rattling got louder and louder...limped home again turning heads all the way...oil colour is normal and general running of engine feels smooth apart from the regular rattling/knocking sound u guys any ideas what the problem is??
The turbo for a 3.0l is like rocking horse poo to get hold of 2nd hand and is a CT12B turbo.I was in touch with a guy in Japan that can supply The turbo for the 3.0l for about £550 delivered and that was new.If you need his contact details let me know
You can also get your turbo reconned for about £500https://www.facebook.com/groups/henpals/
it will run but you don't really want to run it for long like it if it is the turbo as it could cause major damage if it lets go completely.I used mine locally for 2 days when mine went and in the end i had to take it off the road as the noise was terrible.Originally posted by hallysilly question i know but will it run without the turbo on?
If the turbo is sounding like a tin of nails the i would say its gone but you would need to see if there is any play in the shaft inside to know for surehttps://www.facebook.com/groups/henpals/
Normally big ends will result in a drop in oil pressure as well, It could also be a little end if it's got really hot and bothered.Originally posted by BUSHWHACKERDude, put your engine details in your profile under your user name, you will faster responces in future!
p.s. I'm guessing your big ends are on the way out, but impossible to tell without hearing it.Bring me the head of a treehugger
