finally got the new 4 runner and love it, unfortunately so does the wife and she is tuzzing me to let her have it and she is prepared to get rid of her 206cc thats how much she likes it. It will be far more practical for the tracks up to the stables. So I had better start looking for a 3rd gen aswell!!
I digress
The 4 runner has full Toyota s/h with all the paperwork and feels so positive. However the two known faults when I brought it are the rear window and sunroof not working and would welcome your advice:
1) Rear window - motor works, all greased up but stalls/misses gears at certain points. On inspection looks like crescent shaped gear the motor drives has badly worn teeth. Not had motor off but is it fair to say the drive gear on the motor is likely to be poor?
a) Am I right in thinking that the gear mechanism is refered to as the regulator and if so would it be best to change the motor as well.
b) How easy is it to change the regulator. Does the glass need to come out and if so how is this fixed (all looked a bit corroded around the base of the glass!)
c) Where would you source a replacement from (milners = £200+ for motor and regulator)?
2) Sun Roof - motor works but no action. Have remove glass and one side of the slider is fixed the other slides up and down freely. Is it worth attempting a fix (no air con so could do with extra vent) and is it straight forward. Again where would you get parts from?
These questions have probably been asked before but if you could point me in the right direction it would be much appreciated.
Also Service Intervals - the book has intermediate oil changes done at 4500. Does the oil filter need to be changed at this one?
Would you recommend continuing at 4500 or stretch to 6000?
Normal oil - semi synthetic - fully synthetic **** which one and what effect would this have on oil/filter change intervals. is the extra cost worth it. The receipts indicate a Shell oil has been used, any problems deviating from this?
I do about 10- 12k a year so bi-annual servicing shouldn't be too much of a problem however it is the end of those main dealer stamps in the book!!
I digress
