Could Anyone Tell Me What Could Cause A 3.0 Knz Surf Consume Heavy Amounts Of Fuel
Heavy Fuel Burning
Blocked/ dirty injectors also.Originally posted by SILVERFOX205Could Anyone Tell Me What Could Cause A 3.0 Knz Surf Consume Heavy Amounts Of Fuel
are you getting plumes of black smoke, also check the obvious.... That there are no diesel leaks (especially from the top of the injector pump or leak off pipes)Bring me the head of a treehugger
Hi
have you had a look to see if the pump is leaking, i thought my fuel consumption was getting very heavy just lately, when i did a oil change the other day was wondering where all the oil underneath had come from, tracked it back to the fuel pump leaking, only leaks when the engine is running so you dont get a pool on the drive way
