Ok, its not specific to the 3 ltr, and i did post a similar thing in the electrical section but i'll run it by you anyway..in brief, as hopefully i'll be on my way to work in ten minutes!
A few weeks ago, i had a dodgy start..ie, the engine turned briefly, but quite lively! then stopped..the second turn was slow, kinda like the battery winding down..but..on the third attemp she fired up as norm..
This happened at approx 2 or 3 week intervals, about four times in all. Each time it started fine, but after a bit of hesitation on the first couple of turns..Each time it was the first turn of the day, and subsequently it ran fine..until the next time..
OK, i topped up both batteries..bought a starter repair kit from Roughtrax (just in case)..checked the terminals and the earth strap..Had the batteries tested, the result of which being a clean bill of health, (apparently the drop test? showed 600 something...ther guy seemed impressed anyway..but he didn't test them in isolation)
The last couple of days, and things are more sinister..The morning grumbles have turned into an every start grumble..I called Toyota to get two new batteries, but their data base was down and haven't yet got back to me..This morning i tried it, just to see, and it started fine..Went to take the wife to work ten minutes later, and all i got was five relay clicks from behind the radio, followed by a clean start!
Now i'm thinking it ain't the batteries? The radio (origional) has beed clicking off suddenly for the last few months, then, minutes, hours or days springing back to life..Also, approx a year ago i had an ignition barrel changed by toyota when my key got well and truely jammed..Could there be anything astray in that area? or could it still be battery related? It certainly doesn't seem like a starter motor clunk..just a sharp click from behind the radio..grrrr
Well..maybe it'll start..i'm off to work..if not, i'll be back in ten minutes!
no, second thoughts, you'd better not answer that one..The motor factors seem to have one that'll fit, but asking for another, only with the terminals the other way around met with a blank gaze, as if waiting for the punchline! Thats a point, why can't i just turn it around? Gawd, that was probably a real daft thing to say..
