Mate, am in desperate need of the metal intake pipe which runs from the turbo to the intake manifold, and the four double ended bolts that connect it there. I've got a 1-KZTE engine. Any chance? Money/post/pickup all an option. It's getting desperate!
How much for the sensor assembly (including cable and connector) that screws into the bottom of the fuel filter, and how much for the short section of fuel hose going into the inlet side of the filter ?
Hi people
If you can send me some pics of the parts you need then i can take them off and dispatch them to you.
The engine, gearbox, Xfer box and all running gear are still complete.
If anyone wishes to come and remove any bits they require then please do, (cheaper for you that way) my house is No.70 and the postcode is SG28TW or call me on 07930379698
Hi people
Paul
What condition is the hose between the airbox and moulded plastic pipe that runs across the top of the engine?
Hi there, I'm after the central part of the dashboard after some scrote decided to try and nick the useless Japanese double din radio some time back. They didn't get the radio but succeeded in ripping the surrounding dash to bits. The section I need is the heater console and switches and the clock bit, if that makes sense. I'll have a dig around in my dash to find out what's been damaged but what sort of price would you be looking for for this section? Thanks, Simon
I have the dash bits you need, I also have a Clarion double din CD/Cass/Radio with remote control if you want to put one back in.
The dash parts will be £40 + P&P
The Stereo would be £60 + P&P
You would all be better off to phone me as every time i check for messager etc i have to get washed up b4 going indoors, where as i have the phone in my pocket all the time
Paul
