Hi,
I`m looking for a N/Side front driveshaft (cv axle). Also the speedo sender unit which is just to the right where the rear prop. goes into gearbox.
cheers,
chris
Hi There
You need to contact Tony N as the body and all the running gear is now at his place.
Although i do still have quite a few bits left here
Paul
The tail pipe can be yours for £15 + P&P unless you want to collect
Paul
Not wanting 2 muck u about but usual source near me won't be able to confirm what he can get me on the list until Mon/Tues, so won't be able to say either way until
Hi do you have the electric aerial (does it work) as mine has just packed up!!!
Sorry the aerial was knackered B4 i bought the surf.
If yours still has the mast i'll buy it from you as some little scrote decided to try and remove mine.
Cheers will see what i can do,dont know if i can get another aerial for it i was told the Mr2 one fits so i am going to remove it and scour the srappers, if it does i will sort out the mast for you....
Dave roughtrax do a small rubber ariel to fit the surf's wing.You may need to use the bit of the surfs ariel that sits on the outer side of the wing tho so the ariel sits correct on the wing.
Thanks Firefly that'd be great
Also thanks to Stormforce for the info. I want to try and keep to the original if poss, have used "rubber ducks" in the past and found that unless they're up on the roof,the reception is not too good.
