Hi guys,
My surf has developed an intermittent problem. From time to time it has a problem idling. When it kicks in the revs go up and down a few hundred rpm and when i try to clear it with some revs it dumps a lot of black smoke.
This seems to be happening more and more on a journey of any length now. As quickly as it happens it goes away though. After searching on the forum I came up with a few possibilities
- Fuel filter needs changing. This could be the one as I did run it a bit low on fuel a few weeks back and maybe pulled a load of crud through to the filter.
- Injectors blocked. It runs fine as soon as its off the idle so not sure about this one
- Loose connection on the fuel pump solenoid. I found someone on here who had the same symptoms as me and this was the problem.
- Some sort of turbo seal problem?
I have lobbed a bottle of redex in to the tank last night to see if this helps, but I just wondered what I should be checking for as the most obvious culprit. I don't know where to look for the fuel pump solenoid so it'd be helpful if someone could point me in the right direction here. Also is there a write up on replacing the fuel filter anywhere?
Sorry for being such a noob, I've not done a lot of work on this surf to date.
