Turbo light on all the time (4-runner)
  • Turbo light on all the time (4-runner)
    There is another thread, but I don't want to hijack it
    I just got a 3.0TD 4-Runner, drives very well no smoke........But I've just realised the turbo light is on. I can only seen it glowing at night as it looks dim.
    This is on even at idle!
    What can I check? And seeing as it's a new car any chance of pics. I know it's a big ask but I'm too scared to use it now
    Andrew
    1994 4-runner 3.0TD
    Are you sure its a turbo light I didnt think 3.0 litre had them. The surf doesnt but Im not too sure about the 4 runner.
    Trust your Hound.
      This comes up on all the 3.0 searches I did.
      OK, the 4-runners DO have a turbo light, they ALSO have engine fault light, the turbo light does not work like the 2.4 in coming on WITH the turbo. But rather comes on to warn of a turbo over boost.
      I cannot see how I have a problem when the light is on at idle, there could not be enough gas produced to make excesive boost at such low RPM
      Andrew
      1994 4-runner 3.0TD
        Have a read here.....
        http://www.hiluxsurf.co.uk/forums/sh...ght=waste+gate
          problems with the alternator wiring can also cuase the turbo light to come on, but dim
          i once used the wire feed off alternator to activate a relay - so that it would only come on when engine running,
          but had to disconnect it as it made the turbo light come on dimly!
          Landcruiser Colorado
          Sub. Forester
            Cheers, that thread I have read and it looks like the same confusion over the engine fault light and the 2 types of turbo light used on the Surf/4-runner.
            It looks like being the turbo acuator not dumping, either the vac pipe is off/split or the whole assembly is knackered.....
            Anyone got one?
            Andrew
            1994 4-runner 3.0TD
              So went out in the rain (aaarr) and had another look, found 2 vacume relays on the drivers side (no idea....no they are the ADD here http://www.hiluxsurf.co.uk/forums/sh...56&postcount=7 ) and forund the turbo sensor bolted to the inlet manifold.
              Start engine, light goes out, rev to 2000 rpm, light goes on and stays on (bugger). After a while it stayed on even after starting (just after I removed the plug and took the filter out to try that) put all back and the light stays on.
              Even if the wastegate was stuck/FUBAR, should the light go out as the revs dropped (and psi is lost)?
              Any idea how much the sensor is?
              Any other ideas (it's non-efi) I realy want to keep this one and get it 'lane ready' as it runs fine not a hint of smoke!
              Don't supose there is anyone near me in Slough/Reading?
              Andrew
              1994 4-runner 3.0TD
