I really hope someone can help with this as I am at my wits end with my Gen3 3 litre TD KZN185 Surf.
This is a long one so here goes. I got the Surf a couple of months ago and it was in need of a new bumper and valance. Unfortuanately I didn't realise the head was cracked. A mechanic I have used regularly sourced me a new non genuine head with reconditioned cam, valves headbolts and gaskets etc. This was fitted and the thermostat replaced. All at great expense but I thought the vehicle is to good to not repair. After running it for two day we found that the fuel pump was not working properly so a lift pump was fitted.
Now the big problem. When I first got the vehicle back I read that I should leave it over night for the engine to cool down and check the coolant level when cold. The following morning I noticed that the level in the expansion tank was at full but when I looked in the radiator I could not see any water/coolant so I topped it up. I took it for a run and I noticed that the coolant was well above the F mark in the expansion tank but it was not cominig out of the cap. I was told by a couple of mechanics that when cold it woul drop down but it didn't. For three weeks the car ran great and emissions were really low and there was no smoke from the exhaust. I then took the car for a longer run, about 60 miles and I got stuck in a slow moving jam for about 25 minutes. The temp gauge stayed just below half as usual, until I accelerated off where it went up to above 3/4's. I pulled over and the gauge dropped back down and when I lifted the bonnet I noticed coolant had been forced out of the expansion tank. I limped all the way home ensuring the car did not go in the red and the gauge moved up and down contstantly and just touched the red for about 10 seconds and went back down. She seems worse under load. The following day I noticed that for the first time the level in the expansion tank had sropped over night. I then checked the radiator and once again could not see coolant in the radiator. I took her for a run and the gauge stayed still but coolant still came out of the expansion tank. I did the same run the following day without topping up and the gauge went up to just below the red. Since then the coolant has been dropped and another new cooler therostat has been fitted and still the same problem. I can take the expansion tank cap off and touch the coolant after the temp has almost been in the red and it it hot but not unbearable.
Sorry for the realy long post everybody but I am really fed up now and the latest info I am now getting is the block could be cracked.
Please help as I can no longer afford to throw that sort of money at my Surf.
Thanks in advance Simon.
PS sorry for any spelling errors my keyboard is not working properly and I can't delete or insert.
