for the second time this week now while out on a long distance run and everything is up to operating temp, i have noticed that when my veichle is in overdrive or just about to change into overdrive the truck seems to feel that the engine is hesitating or a very slight misfire (as if it where a petrol engine) it only happens in overdrive because if i press the switch off and the revs lift its fine, it seems to happen just on the 50mph to 55mph as if its hovering to engage or not and can't make up its mind,
i have also noticed today that the speedo is sticking between 40mph and 60mph and jumps to where it should be if i tap on its cover (don't know if its related)
i drained off about 4.50 liters of atf and replaced it a few months ago and can't really say it was perticualy gungy but it was no longer any way near as red and clean as the new stuff. should i do this again? or is this problem down to something els,
