The tailgate window has become slower and slower to the point where the motor is still going, but the window doesn't move but just makes a 'bumping' noise.
It worked for a while with a helping hand but won't go all the way up. I just found out that with very little pressure I can slide the window most of the way down without engaging the motor at all.
I'm thinking the teeth on the cog at the end of the motor spindle might be badly worn. If so, will I have to invest £130 from Milner for a full replacement motor, or can I buy the drive cog seperately?
As I've not stripped it down yet, I'm not sure this is the problem though.
Does this sound familiar to anyone? If so what do I do without getting a severe twist in my wallet?
