Big problems, though maybe not as bad as it could have been. I drove my 3.0TD surf to the airport everthing seamed OK parked up came back a week later tried to start it Clunk! it sounded like a big problem so I took the top bolt and clip off the cam belt cover so I could lever it away and see inside. No cam belt tension, the clunk was the piston hitting a valve I assume.
As it wasn't running at the time I hope I will get away with just putting a new belt on. What do you think?
Also has anyone got any info on timing marks etc?
Cheers Martin
Cheers Martin
