Just failed the mot on my knz185 3rd gen, the steering rack is leaking
is this going to be expensive to replace or is it just a seal that needs replacing, i have had a look under the veichle and the leek is eminating from a small clyinder block shaped object on ther rack which looks like has a nut on it..does this come off or is it a sealed unit...looked on roughtrax and they have a steering rack bush kit but it looks nothing like whats attached on mine, but i do not know what the part is called on mine...is this wot i need?
Thanks
is this going to be expensive to replace or is it just a seal that needs replacing, i have had a look under the veichle and the leek is eminating from a small clyinder block shaped object on ther rack which looks like has a nut on it..does this come off or is it a sealed unit...looked on roughtrax and they have a steering rack bush kit but it looks nothing like whats attached on mine, but i do not know what the part is called on mine...is this wot i need?Thanks
