Hi guys,
So my engine conversion finally got done and i now have the 1KZ-T engine running in what was a 2.2 petrol hilux.
However, the 1KZ-T now doesn't start as easily as when it was in its native home of the 4runner.
The garage that did the swap said they wired the glow-plugs onto a button which i press on the dash instead of being on the ignition key. Additionally the battery they've used is the one which was in the petrol hilux - although it is brand new.
What do you guys think is the likely culpret?
Cheers, Paul.
edit: more info - the engine turns over ok at seeminly the correct speed but it takes a while for it to catch and fire up.
Cheers, Paul.
