Originally posted by Ricksurf
I just had a look on the Roughtrax site (slow day) and they said this about one of their clutch kits:
"Clutch Kit diesel 3.0 litre, contains friction plate, pressure plate and thrust bearing. Fits KZN185, & UK 4 Runner. We have also found many KZN130 model Surfs run this larger 260mm clutch plate diameter clutch, however the only way to be absolutely sure is to measure the clutch plate first. If fitted with the 260mm plateuse this CL016 kit, or if the smaller 240mm plate is fitteduse the CL005A kit"
You might have the wrong size clutch plate in there.....
