Hi Guys....Have today changed all the break pads and shoes on surf
I used an easybleader kit to change and push all the old fluid and air out of pipes....NOW... I had this problem before i started thats why i changed the pads & shoes to see if it would solve the problem. But i still got it...
The problem is... With the engine running..pump break pedal and hold down
pedal slowly travels to the floor....Ran another check with easybleader.same problem....have put two big dot 3 bottles through system.... all nipples are tight...I am and never was loosing any fluid before i started...Have checked
all vacume pipes for splits or breaks...none...But with engine off pump pedal and hold and the pedal is hard with NO travel...Is my servo knackered And if so wheres the best place to get one........thanks
