Temperature sender
  • Temperature sender
    Does anyone know if there is a spare tapping in the water jacket that I can use for a temperature sender (like there is in the 2.4 thermostat housing). I've had a quick look but can't see anything obvious.
    Roger
    I use the undrilled opening on the alloy elbow that comes out of the head to the top hose of the rad, faces up as you look at it.
    Drill it through and tap it with what you want.
    I've not found any spare plugged holes like the 2.4 Stat housing has.
      Cheers - I'll have a look when it gets light ..... and stops raining ...... and blowing ....... and warms up ...... about June then
      Roger
        Are there coolant lines for the turbo on the 3.0L? I know Nev made an inline
        adaptor to fit into the turbo coolant feed line for his 2.4 manual, as they don't
        have that extra point on the housing. His image is below. (Hope you don't mind
        me nicking your pic Nev?)
        Sender adaptor
