Went into Tesco to fill up with diesel, and had one hell of a problem getting the key to turn in the ignition. It's as if the steering lock was on, eventually got it going, got home took the key out and then reinserted the key, same problem.
Squirt with WD40, left for a couple of hours, went outside to try again, and took about 5 Min's to get the key to turn.
Any ideas or fixes would be greatly appreciated.
