Oil change went with out a hitch. Might not sound much but for someone who only has to look ata spanner to break something Im pleased.
I put in 7.1 L as advised by Toyota and the manual, but it seems a bit high on the dipstick. Will this cause any problems?
Also, the oil pressure seems lower. Pre oil change it sat around a third of the way up at most times. Now it is v low at tick over and rises to about 1/3 of the way up under load.
I seem to remember from an old renault I had years ago that the oil pressure gauge should rise and fall with different loads but thought I would ask the experts.
