Hello all, My GEN 3 is in getting new seals and bearings on the back, I have just called the guy and its all going well. However, He is a bit stumpped !!!! the seals on both sides have gone but the bearings are in good condition with no play. when he removed the half shafts, he has spotted that on the passenger side rear, the abs pick up ring and sensor (in the axel) have been touching!!!! the drivers side (was leaking but only a little) is fine with no sign of contact.
Dose anyone know what might cause this!! He is going to have a look but thinks the ABS sensor on the axel may have been installed at some point with a washer or seal missing?? hence is .5mm lower and touching... Dose this make sence? as he said the bearings are fine.. Any help from you tech lot would be great OR anyone had this problem before? CHeers
