The motor has sounded a bit more rattly than usual this weekend (tappety type noise) so figured I need to do an oil change.
However, would this lead to higher than usual oil pressure too? I was thinking oil filter a bit cr@ppy or suchlike as I do two oil changes to one filter normally.
Is a filter and oil change likely to cure my ills or do any horror stories spring to mind?
, on my boat engine I just made sure I had an accessable union I could measure the pressure at, and kept the electrical guage for safety and convenience.
