Should there be an air temp sensor located in the air filter canister on the side nearest the bulkhead? I have a rubber grommet which draws in air. I notice the 2.4 models have a sensor on the air intake pipe. The 2.4 position for the sensor is also as indicated on the 1KZ repair manual online.
My 3.0TD doesn't have it on the intake pipe ...... just this hole! If its missing I wonder where the wires to the ECU have gone and why?
Cheers Guys! I am Newbie to 3.0TD so go softly.
No problem Nev. My other issues are sort of white bellowing smoke type problems! Yes that boring old one again.
which was from ukcylinderheads fitted elsewhere.
probably knowing my recent luck.
