On my return from work i pulled forward to reverse into my parking space and reverse felt like it wasn't engaged properly, it felt a bit like a clutch slipping on a manual surf, mine is automatic, when i got out there was a trail of fluids on the ground and when i looked it was an oil of some type but i could not see where it was coming from allthough i had just driven over 25 miles and the oil was not hot. Just when i thought it couldn't get any worse water started to leak from the radiator (i could see the anti-freeze in it) has anyone got any ideas as to what it could be ?.
The engine is running fine and there are no unusual noises.
